TX on 136 Khz
My Flex 6400 will TX out of the XVTA port at 0 dbm on 476 Khz.
However, on 136 Khz it is blocked.
Is it possible to get a turf file that will allow TX on 136 Khz?
VK6AKT
I thought I would let those interested in this post that I did submit a help desk ticket and the answer I got from Tim Ellison was (TURF files are only applicable to the operation of the PA and not the transverter port. The DAC in the FLEX-6000 is not capable of transmitting at that low of a frequency.).
So, help desk was a waste of time.
However, after further investigation I noticed that I had the PTT inhibit box ticked in the band settings.
Once I enabled the PTT on 2200m my Flex 6400 does transmit at 0 dbm out of the XVTR port, more than enough to drive a custom built Fet PA for 136Khz.
Hmmmm... Are you sure you have the XVTR output (red) selected on your slice? (Just asking as this is a mistake I make ALL the time :-))
Also, have you selected CW as output mode? SSB might be too wide for the available bandwidth... Here in Canada we're only allowed 135.7 to 137.8 and phone is not allowed.
Hi Don
Thank you for your suggestions unfortunately I have XVTR selected, and bandwidth is correct.
I use the same settings on 476 Khz to drive a 200W Fet amplifier and that works fine. VK6 to KH6 on WSPR
It looks as though I will have to contact Support and see if they will supply me with a Turf file that will enable 136 Khz TX on my Flex.
Ken
VK6AKT
- 408 Community Topics
- 705 The Flea Market
- 206 SmartSDR+
- 464 SmartSDR for Mac
- 223 DAX
- 124 Aurora
- 984 Genius Products
- 360 Tuner Genius XL
- 328 Shack Infrastructure
- 233 Networking
