Interfacing LOG40M without SliceMaster?
Is it possible to integrate LOG40M with a flex 6xxx series without using SliceMaster? the User Guide from Log40m only talks about using Slicemaster and Hamlib. Slicemaster is nice, but I don't really need it.
If others are using Log40M without S/M, I'd really like to hear how they have the settings in Log40M and Flex set up.
Thanks.
I use Log4OM and don't have Slicemaster. Here are settings I use on Log4OM and Flex/CAT:
Thanks jlyonmn....this is great. Much appreciated.
Did you have to install omnirig separately from Log4om?
If I remember right (it was over a year ago), there were two versions of Omnirig - a newer and an older version. You need to install the old version. DX Atlas: Amateur Radio software
I had quite a slog getting these programs to talk to each other but hopefully you should have an easier time of it. If you get stuck, I would be happy to connect with you via Zoom or Teams for some screen-sharing.
Jeff
Thanks Jeff, much appreciated! I now have it working.
As you said, v2.1 of Omnirig doesn't want to work with Log40M. With your link, I found v1.2 and installed it.
I'm not doing FT8, so I didn't bother with the sound settings in Log40M.
Also, for others, the steps are:
a) Run OmniRig. Make sure the parameters are as shown above (except select the appropriate COM port from SmartCat. DON'T click OK at the bottom. -- that will shut off OmniRig and then SmartCAT won't connect to it. Just leave the screen up.
b) Run SmartSDR. Make sure you have selected to have SmartCAT initiate automatically. If you want, you can check that OmniRig is connected by looking at the SmartCAT screen. Under the COM port, it should show 'omnirig'
c) Run Log40M and everything should be connected.
Congratulations Don!
The Log4OM user forum is a very good source for information about the "how to" questions re. Log4OM. Although the guy who runs it seems more than a bit crabby most of the time. He will usually refer users to the operating manual.
Jeff
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
