SmartSDR v4.3.19 | SmartSDR v4.3.19 Release Notes
Slice C with DXLab Commander and Spot Collector?
Is it possible to use the Ports tab in DXLab Commander config and the SmartSDR CAT panel to be able to control a third slice, i.e., control Slice C? What I am trying to be able to do is click on a station\spot in SpotCollector and have the frequency in Slice C change but not affect Slice A or B. I can control Slice C, with a port setting but whatever I do also affects Slice A.
Thanks and 73,
Bob WK2Y
To quote https://www.dxlabsuite.com/dxlabwiki/FlexSignature
"Commander will track and control your Flex-6000's
- VFO A frequency, mode, and RX bandwidth using the transceiver's Slice A
- VFO B frequency, mode, and RX bandwidth using the transceiver's Slice B
Other VFOs provided by your transceiver are ignored. References to VFOs in this article are limited to VFO A and VFO B."
Thanks Bob. It's interesting because I can get spots to show up on C and C will track A or B so the other VFOs are not exactly ignored. When I set up a Com port attached to slice C and use it as the primary or secondary in Commander, it follows A or B and C knows the process and shows it as CI-V Commander. I was hoping there was something I was missing or a trick, maybe by defining slice 3 as a different radio in multiradio?
Thanks again.
- 419 Community Topics
- 719 The Flea Market
- 229 SmartSDR+
- 213 SmartSDR for Maestro and M models
- 474 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 143 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 335 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
