Maestro can not see wifi 6 (ax) networks
Doug
Doug Member ✭✭
I decided to update my network to wifi 6 wired with cat 6 cable and it is kicking ****...... but... the maestro can not see the network unless I disable wifi 6.
Has anyone else experienced this?
I've just begun digging into it ...
Is there a known workaround / config change / update to the maestro that will resolve this?
  • KM4CQG
    KM4CQG Member ✭✭
    Doug
    I have the AX12 my Maestro did the same because there is a security parameter.
    Im not at home to tell you but hunt and peck around the Netgear program under advanced.
    Ian
