Using SmartSDR 2.8 and considering moving to 3.3.x ...
Been looking for a FAQ that outlines the differences between 2.8 and 3.3.x. If such a FAQ or thread exists, please point me to it.
We are using 2.8 with a FLEX6400 in a local/remote setup and it's been working fine. We don't need to multi op features of 3.3.x but we are wondering if there are any performance enhancements in 3.3.x which are not present in 2.8.
So, does 2.8 offer the same performance as 3.3.x (minus the multi op stuff)? I wonder if the NR is better? More features?
Our FLEX6400 does not have the tuner and we are using an Expert 1.3K-FA amplifier without any issues.
  • VE7ATJ_Don
    VE7ATJ_Don Member ✭✭✭✭
    Hi Bruno... as far as I'm aware, the code used in 3.3x and 2.8 is pretty much the same, except for the multi-op functionality. I don't believe you'll see any 'performance' difference between the two. There is, specifically, no difference in the NR functionality/performance.
  • W4AFK Bruno
    W4AFK Bruno Member ✭✭✭
    Thanks Don ... then we will stay with 2.8 as it is working just fine for us :-)
  • John KB4DU
    John KB4DU Member ✭✭✭✭
    If it works, don’t fix it.
  • VE7ATJ_Don
    John.... "if it works, don't fix it"... unless you're adding new 'features' or 'making it work better' :-)
    (I can't count the number of radios/appliances/etc. I've ruined trying to add new stuff to them...)
  • David Decoons, wo2x
    One feature in 3.X that I love is Smart Control. This allows SmartSDR for PC or MAC to be running then use controls on front of M series radios or Maestro.
    Handy instead of reaching for the mouse.
