Need help programming mode changes in Streamdeck
Rick N0VT
Rick N0VT Member ✭✭✭
edited July 2022 in Third-Party Software
I've had a Stream Deck a few months and have it set up per FRStack's REST help page. But I'm having a problem making one command work.
What I want to do is program buttons to change the mode of the active slice between "USB" and "DIGU". I set up 1 button as: http://localhost:13522/api/ActiveSlice/MODE?param=USB and a second button the same way except the param=DIGU.
When I press either button, the Flex starts alternating between the modes--USB/DIGU/USB/DIGU and the only way to break the sequence is to close Stream Deck. It's what I might expect if I were holding both buttons down continuously.
Q1: What am I doing wrong?
Q2: Is there a way to set up a single button to toggle between the two modes? I can't find it if there is.
Tnx
Rick N0VT
Best Answers
  • Rick N0VT
    Answer ✓
    Thank you. I'll send shortly.
  • Rick N0VT
    edited July 2022 Answer ✓
    In case anyone else has this issue, Mark fixed my problem by putting the param above in brackets, creating a "click action" instead of an "always on" status, using the "Click Param" line in Stream Deck.
    Bad command:http://localhost:13522/api/ActiveSlice/MODE?param=USB
    Good command: http://localhost:13522/api/ActiveSlice/MODE[?param=USB]
    Mark said "... both USB and DIGU buttons were set to send command when polling. I moved the param to click action for both buttons, reset the stream deck and retested. The issue went away."
  • Alan
    Alan Member ✭✭✭✭
    Rick
    I ran your REST mode change command in my browser as a test. Looks good, and I did not observe the same as when you ran it from Stream Deck. So....two thoughts:
    • Its a Stream Deck issue
    • You have another device sending a mode change command.
    Hee is a screen shot of the mode change command running in my browser.
    Alan. WA9WUD
  • Mark_W3II
    Mark_W3II Member ✭✭✭
    Are you running any other FlexAPI or CAT radio client software like DXCommander, etc? If yes, stop all other software except SmartSDR, FRStack and StreamDeck then retest buttons.
    You could also post your SD profile here so those of us that have SD also can review.
    73, Mark W3II
  • Rick N0VT
    edited July 2022
    No other software is running.
  • Rick N0VT
    edited July 2022
    Alan-I closed Stream Deck and ran the link in my browser the way you did and it works like it should. No changing back and forth. When StreamDeck is running, it bounces back and forth.
    Rick N0VT
  • Mark_W3II
    If you want me to look at your stream deck profile please email it to me. You can find the support email address in FRStack Help menu.
