RemoteRig Voice Setup
Val DM1TX
Hi all,
I have here a new RemoteRig kit. CW works fine and very easy to set up. I want to use the original FHM-1 microphone too. Can anybody help with some ideas how to set this up? There are some suggestions in the RemoteRig manual but did not work. Do I need an extra cable for the main unit? On the radio side I guess only a cable is necessary. Appreciate any ideas.
To use an RR, you'll need to do the following beyond the usual network settings for RR.
- Connect the RR Radio end to the MIC input on the radio. Not Line In.
- Connect the RR PTT to the PTT on the radio
- Select Radio Mic input on SmartSDR (make sure you have the correct radio input)
- Jumpers on the RR Control end wired for Yeasu HF Mic
- Test PTT on the MIC and see if the radio goes into TX.
- Set MIC Bias off on SmartSDR
- Test with the +20db boost on SmartSDR
- Set your MIC gain as required on SmartSDR keeping the Voice Peaks on the Level meter to below -5dbm
- You might have to adjust the MIC Gain in on the RR User end and the MIC gain output on the Radio end
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
