using flex 1500 as a receiver with a DX-60
I enjoy my flex 1500 very much but I would like a little more power at time an I have a Heathkit dx-60 that is a good transmitter and would like to have the great receive of the 1500 your help would be greatly appreciated Than you
  • Trucker
    Trucker Member ✭✭✭✭
    edited June 2022 Answer ✓
    It might be easier if you found an amplifier like the Hardrock 50. 3 to 4 watts out of the 1500 will drive the Hardrock 50 to 50 or 60 watts. Modifying the DX-60 would require a lot of work. Plus, you would need to retune the finals if you change frequency very much.
    And finally, the DX-60 does not cover 60,30,17 or 12 meters. Personally, I think it would be cheaper to buy or build a solid state amplifier.
