DAX Corruption
Larry _ NY8T
Member ✭✭✭
For those that also are having this issue, see if you have any DAX channels turned on in DAX Control panel that are not curently assigned to a slice, if so turn them off. Owning a 6700 I can turn on the 7 unasssigned DAX Channels and within a couple WSJT-x decode cycles it will go into corruption, then I can turn the unassigned channels off and it is back to normal without restarting DAX. If I Only have say one unassigned DAX Channel turned on, it takes longer for the corruption to happen, but as soon as I turn that unassigned DAX Channel off it corrects itself without having to restart DAX. Try it and see what you get.
- 685 The Flea Market
