Monitors
Can I run my 6600M using the HDMI monitor output on the back AND one or two monitors from my laptop??? at the same time........
    Answer ✓
    You can run in MultiFlex mode, but then the front panel will operate one logical radio and SmartSDR the other. What you see on the HDMI monitor will be what you see on the front panel. What you see on the SmartSDR screen will be different. If this is what you are after, then you are all set.
    I suspect that this is not what you had in mind. Take a look at the SmartControl section of the Maestro documentation. With this option, you get the big screens of your PC running SmartSDR and the functionality of the knobs and buttons on the front panel.
    What is not supported is SmartSDR and the front panel showing the same slices simultaneously.
  • jrc213man
    jrc213man Member ✭
    I am a new user. This was a great answer and very helpful. Thanks! Jim W0HJ
    Glad I could help. Welcome to the Flex world!
