Bozo Hint of the Day : Spots and N1MM
Andrew O'Brien
Member ✭✭✭
Don't spend 15 minutes scratching your head trying to find out why spots from N1MM are not making it to SSDR panadapter , reading the instructions 3-4 times, checking all the settings 5-6 times , AND THEN eventually realizing you had your spots levels set too high in the spectrum display for you to see . A reduced waterfall -to-spectrum ratio fixed all. I had SSDR window reduced so I could see it while setting CAT ports up.
Duh ! 🙄
Andy K3UK
- 692 The Flea Market
