DAXIQ's and CW Skimmer
I just installed CW Skimmer using SDR Bridge V3, under Windows 10 with my 6500. For the initial configuration I brought up two pan adapters, A&B. In SDR Bridge, for “A” I assigned DAXIQ 1 and for “B” I assigned DAXIQ 2. In PSDR I selected the same DAXIQ’s. Everything worked just fine. The next day, using only one pan adapter, “A”, I brought up CW Skimmer – it appeared it was not connected to the 6500. Checking, I discovered that DAXIQ 2 was selected. I changed it to DAXIQ 1 and the program was now receiving data from the 6500, however clicking on any decoded signal would not cause the 6500 to change frequency. Rebooting SDR Bridge and CW Skimmer allowed all to work just fine. What is even more confusing, if I look at the SDR Bridge configuration, it always shows the correct pan adapter to DAXIQ association. Changing bands also recreates this problem
If I shut everything down I can repeat the above every time. Isn’t SDR Bridge suppose to remember which DAXIQ is associated with which pan adapter? I’m thinking that there is some simple step I’m missing.
- 419 Community Topics
- 717 The Flea Market
- 225 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 143 Aurora
- 389 FLEX-8000 Signature Series
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 334 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
