JS8Call changing mode
I am using JS8Call and have it set to "USB" for the radio control. The options are USB and Data. If I select "USB" the mode on the flex is changed to USB (not DIGU) and drops digital mode. If select "Data/PKT" in JS8 then flex assumes LSB (40m standard) and then I am in DIGL which is obviously not correct.
I tried to set a memory for that frequency and use DIGU and when you select that memory, it sets that mode. But as soon as JS8 transmits, it changes it to DIGL (if Data/PKT is selected in JS8) or USB (if USB is selected in Js8).
Is there anyway to keep the flex from changing the default USB/LSB automatically?
Hmmmm... this sounds like a problem with the call the JS8 software is making via the Flex API's (or through the CAT commands). I don't work with JS8, but does it have a 'rig configuration' selection/drop-down? What rig have you selected?
It's a little convuluted because I'm running Linux and using nDAX for audio. I was using FLRIG as my radio control, and selecting "FLRIG" as my radio (the radio is defined as a TS-2000 in FLRIG).
Currently, however I think I have a workaround. I was trying to use FLRIG for it's functionality, but have been using nCAT now (which isn't my first choice for rig control due to the limitations of it only supporting hamlib at the moment) and it doesn't change the mode on me. It's just using hamlib restricts me from using things ARDOP now with the configuration I have.
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 93 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
