JS8Call changing mode
I am using JS8Call and have it set to "USB" for the radio control. The options are USB and Data. If I select "USB" the mode on the flex is changed to USB (not DIGU) and drops digital mode. If select "Data/PKT" in JS8 then flex assumes LSB (40m standard) and then I am in DIGL which is obviously not correct.
I tried to set a memory for that frequency and use DIGU and when you select that memory, it sets that mode. But as soon as JS8 transmits, it changes it to DIGL (if Data/PKT is selected in JS8) or USB (if USB is selected in Js8).
Is there anyway to keep the flex from changing the default USB/LSB automatically?
Hmmmm... this sounds like a problem with the call the JS8 software is making via the Flex API's (or through the CAT commands). I don't work with JS8, but does it have a 'rig configuration' selection/drop-down? What rig have you selected?
It's a little convuluted because I'm running Linux and using nDAX for audio. I was using FLRIG as my radio control, and selecting "FLRIG" as my radio (the radio is defined as a TS-2000 in FLRIG).
Currently, however I think I have a workaround. I was trying to use FLRIG for it's functionality, but have been using nCAT now (which isn't my first choice for rig control due to the limitations of it only supporting hamlib at the moment) and it doesn't change the mode on me. It's just using hamlib restricts me from using things ARDOP now with the configuration I have.
- 419 Community Topics
- 718 The Flea Market
- 226 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 143 Aurora
- 389 FLEX-8000 Signature Series
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 334 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
