Where is the menu on the flex 6600m to allow out of network Maestro to connect remotely?
Hi Carl, to connect remotely, you use SmartLink. There is a detailed explanation in the SmartSDR documentation.
There is no menu option for this functionality.
You start by signing in to the SmartLink server and establishing your log in credentials. Once that is done, SmartLink knows how to connect to your radio and brokers any connection requests.
Once a SmartLink account is set up, the remote Maestro just does a normal startup which causes it to look for a radio. When it doesn't find one, it connects to SmartLink which validates your credentials and tells the Maestro how to connect to the remote radio.
Once connected, SmartLink is out of the picture - it is just there to validate and broker the connection.
EDIT: Link to a video about SmartLink
https://youtu.be/kMbi3dAiMi0
- 684 The Flea Market
