Best alternatives for RX antenna selection on a 6600
Ty K3MM
Since there is no RX Out port AND you apparently cant change RX antenna inputs while transmitting on the other slice, what are people using to set it up for switching between the TX antenna and RX antenna(s)? I used to run a RX out line through a port of a K9AY RX selection system, but need a n RX output from radio for that to work. I'm currently using a GH RX 8x2 switch, but need a way to put it on the external relays get the TX antenna through it on RX.
- 693 The Flea Market
