Turn on the Expert 1k-fa in remote...
Steph
Hi,
I have a cord that connects my 1k-fa expert to the USB connector and the RCA-TX1 socket on the Flex-6600M.
When I'm remote, I can't turn on the amp using the 'Expert Console' because from it, there are only 6 ports (COM1 to COM6) available.
The ports created by SmartCAT are all on top and there doesn't seem to be a way to change the port number.
Do you have any idea how to do this?
73 de Steph, F5NZY.
73 de Steph, F5NZY.
You need a second cable, a serial cable from the RS232 port on the expert to the PC using either a on board serial port or you can use a FTDI usb to serial cable. What ever that com port number is will be the correct com port for the Expert Console Software configuration.
Thanks Larry.
I have another TRX that I use in remote with the remoterig boxes.
The RS232 port on the Expert 1k-fa is already connected to a COM port on the remoterig box.
Do you think I can put a splitter?
730 -
Not sure
of which version of remote rig you have but it supports the 1k-fa. Wondering why you can not control it with remote rig?
- 394 Community Topics
- 670 The Flea Market
- 177 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 80 Aurora
- 982 Maestro
- 954 Genius Products
- 350 Tuner Genius XL
- 130 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 146 Amateur Radio Interests
