TGXL Utility Upgrade and Memory Retention
DonS
Member ✭✭✭
It was mentioned by some that when you do a utility update that memory would be "wiped" clean. I updated the utility / firmware yesterday to v1.1.8 and it appears the memory was not affected. I did not have to go through the process of setting up memory again for my 43' vertical.
Don - kx9q
Don,
The "reported" Memory wipe out was on the 4O3A 1.1.6 Version. not the 1.1.8. When I did my upgrade it processed just like one would expect. All previous settings were intact.
- 996 Maestro
