Occasionally Lose Audio From 6500
JohnK2CIB
Occasionally I lose the audio from the Flex and it has been going on for a long time. Dax shows slice 1 with fine audio. Turning it on and off doesn't help. Dropping SmartSDR and bringing the radio back up doesn't help. Changing from the headphones to the speaker doesn't help. Other apps can output fine audio. Nothing I can do in the computer helps. Strangely, even though DAX shows it is receiving audio, cycling the Flex-6500 in the remote shack does the trick. Wierd. I think that the audio, which is carried in a UDP stream, has the wrong codes or header for SmartSDR to decode it.
- 688 The Flea Market
- 105 Aurora
- 974 Genius Products
