TX RCA Output Setting via API?
K6HN
K6HN Member ✭✭
How does one set the TX Band PTT output settings active or not via the API?
RCA TX1,TX2,TX3,ETC...
Or is this not available?
Best Answers
    Answer ✓
    Hi Gary, it is not obvious, but the way to do that is with the Interlock command. Here is a link to the Wiki location of the info. I have not tried this yet, so I don't know if there are any other tricks to using it.
    TCP/IP interlock - SmartSDR Wiki (flexradio.com)
  • Alan
    Alan Member ✭✭✭✭
    Answer ✓
    Hi Gary
    Try this;
    interlock tx3_enabled=0
    interlock tx3_enabled=1
    Alan WA9WUD
  • K6HN
    K6HN Member ✭✭
    I saw those commands, but the description was unclear making me think it was an "interlock' and not a TX output. I'll give it a try. Thanks Len and Alan!
  • K6HN
    K6HN Member ✭✭
    That format worked. Thanks guys!
    I'm glad you got it working!
