MAP65 and WSJT-X for EME on Flex 6600
Ignacy
I am thinking of using Flex 6600 for EME. Does anybody run it with MAP 65 and possibly WSJT-X? Just one polarization.
Assume the input is XVTA for slices A and B. Then slice A could be used for WSJT-X and slice B for MAP65. Another possibility is to use only slice A with a split.
One advantage of Flex would be ability to use thin cables if the transverter and the amp are located by the antenna.
Ignacy, NO9E
- 110 Aurora
- 322 Shack Infrastructure
- 227 Networking
