Setting RF Power to Zero
I do testing for Node-Red with the Flex and when I want to test where I need to xmit I set the rf power to zero so that I don't xmit. I noticed that the pa temp would increase slightly and the other day I was doing this while testing a FT8 flow and where I replied to a cq. I was surprised the the op called me back. Then I realized even with rf power at zero apparently you are still transmitting a signal. So now I always have an antenna or dummy load when I do xmit tests.
Wondering if any has any thoughts on this.
Regards
Hi Mick, I notice that you posted this in the Legacy Radios category (Flex 5000,1500, etc). Are you seeing this behavior on a legacy radio or on the current 6000 series?
It is entirely possible the low level input (also on the transverter output) was leaking through too your antenna, even though the power amp (100w) was set to no amplification.
Len, its on a 6600.
Ted, maybe, but why would I see the PA temp rising...It's not a big deal, I just know now to keep a dummy load or an ant connected...
Regards
Hi Mick, I will see if I can reproduce the issue on my 6400 so that you will know if this is a one-off problem with your rig or an issue with SmartSDR generally.
In order to acheive linear amplification, Class A, AB and B amplifiers draw a continuous bias current even when no signal is present. This, obviously, will generate heat in the amplifier.
73, Craig KØCF
HI Mick, on my 6400 running 3.2.39, zero RF means zero RF in all modes. I used WSJT-X in FT8 mode and got zero signal out if the RF Power was set to zero in SmartSDR.
If you are getting RF out when the slider is at zero, I think you should submit a help desk ticket.
Hello Mick,
Is it possible that you are changing the RF output on one band, but that when you change bands the TX Band Settings is changing the power for THAT band? (TX Band Settings table remembers the power output on a band-by-band basis)
If you want to completely turn RF output off, then you can set the MAX POWER setting to 0 in the "Settings Radio Setup TX" table.
I keep a dummy load on ant2 for testing stuff.
Guys,
sorry I got so tied up at work I forgot to check the post.. To answer the questions. The power was a zero. I am watching it using Node Red and the radio at the same time. RF = 0, Tune = 0. I have been testing like this for some time. Here is a pic of what the issue is...
In the pic I am transmitting (vfo freq in red) and power is 0. Yet you can see the temp rise. I would never had thought much about it except when the OP called me back on FT8.
- 111 Aurora
- 322 Shack Infrastructure
- 227 Networking
- 146 Contesting
