How to change Radio Panel from slice A to Slice B
I have a 6400. With two slices open, how do I switch the Radio Panel from slice A to B and back?
thanks,
John
Hi John, the slice that is "active" will show in the panel. Assuming that you are using SmartSDR for Windows, click on the flag of the slice you want to be the active one. You can also click on the vertical line when you get the hand cursor icon. The active slice will have a yellow vertical line at the carrier frequency and the inactive slice will have a red line.
The mouse wheel will control the frequency of the active slice, so this is a really handy thing to know.
Len - thank you very much!
John
And FRStack can be set up to have the TX and Rx audio follow the active slice, which is not the normal behavior.
is there a basic tutorial on how to set up FRStack?
There is help documentation with the download, and there are a few YouTube videos. And just play with it, it won’t break.
Thanks for this answer! New Flex 8600M owner here - I want to learn by trying rather than googling but this has been driving me crazy for the past few hours.0
- 684 The Flea Market
