Asymmetrical phases array tuning
I have a phased array on 40 meters and because of the layout in my backyard its SWR is not the same in each direction.The TGXL has only one solution for 40 meters so when I change directions using my Antenna Genius and OM,I must click on the TUNE position of the TGXL... it cant sense the change in direction... Are thee any ideas of how to have the TGXL automatically go to a tuning solution for the array position selected??
Make sense??
TNX AH0U
  • K1ESE
    K1ESE Member ✭✭✭
    How about instead of switching directions with the Antenna Genius you use two of the ports on the TGXL? Keep one direction on the AG and put the other direction on another TGXL port.
