Find the data to display the panadapter
Hello
I use Smart API TCP to read after sending the command 'SUB METER ALL' via the TCP port the different meters.
The data is after "8002" without problem.
After sending the command 'SUB PAN ALL' via the TCP port the data for the drawing of the panadaptor is after "8003".
Unfortunately I do not receive the '8003'.
The meter and panadapter data are read on the UDP port.
Has the API changed or can you tell me how to find this data.
A few years ago it worked but unfortunately I lost the program.
Thanks for your help .
  • Clay
    Clay Member ✭✭
    Hi Philippe,
    In order to receive the pan data, you need to declare your program as a GUI.
    See the API Wiki under TCP/IP Client:
    C[D]<seq_number>|client gui [<client_id>]
    Clay, AB9A
  • Philippe SEQUE
    [{"insert":"Thank you\n I simply search as I do to process the information counters read the information to draw the panadapter . The counter info I find them after the sequence '8003' and normally I will have to find the information panadapter after the sequence '8002'. \nThese sequences are in the stream sent by Flex on the UDP port\n"}]
