no compression meter activity?
Must be 'pilot error', but it's been a long time since I've seen the compression meter working.
v3.2.39 SW
MIC input with no bias (dynamic) and +20 dB gain
FM or SSB mode
PROC on
MON on
DX+
DAX off (of course)
mic gain anywhere from 60 to maxed out (clipping indication is easy to achieve)
Once upon a time I know I could get compression meter to kick in, but not anymore.
Ideas?
Tim AD7TS
  • K0FLY
    K0FLY Member ✭✭✭
    Tim:
    You have changed the TX equalizer. The equalizer settings affect the TX gain in the voice modes. Go to the TX equalizer and bump the settings up about 2 dB then look at the compression, if none bump them up some more.
    When I got my Flex I was running the TX equalizer around zero and below. My friends told me that my 60 year old S-Line had more talk power. I reset the TX EQ up to above zero, I then Igot compression readings and everyone like the signal.
    Hope this helps
    Gayle K0FLY PS: I dont like a lot of compression but a little is OK to get the talk power up.
