No RX Audio on 20M USB
I am using the latest version of SmartSDR Mac. This morning I came into the shack and my Flex 6700 was set to 40M LSB. Everything worked fine. I changed bands to 20M USB and there is no RX audio even though the s-meter bar graph and Panadaptor show the presence of signals. If I change modes from USB to CW or LSB or any other mode, I get RX audio on 20M. Just for grins I checked and there is RX audio on all other bands.
I have restarted SmartSDR, restarted the 6700, and restarted the computer. Nothing solves the problem. Does anyone have any thoughts?
Hi Ken, I would do a factory reset. Export your profiles first, then follow the instructions in the SmsrtSDR manual for doing the reset.
If that does not fix the problem, submit a helpdesk ticket.
Thanks Len, the factory reset worked. I am grateful to you for providing the end to a very bizarre experience.
Excellent, I am glad that fixed it!
I have/had a similar problem. CW audio but no USB or LSB audio. I turn off everything - including disconnecting the Flex from the power supply. Then I wait a couple of minutes and reconnect. That fixes it but how can I get the permanent fix? Factory reset?
@k0FUZ If it happens more than once, I would export your profiles and do a factory reset.
If it continues to happen after a factory reset, I would submit a help desk ticket.
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 93 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
