Maestro and Radiosport RS55SL headset: what's the right profile?
There's no default profile for the RS55SL built into the Maestro. I'm testing with the RadioSport DX M207 profile (which I chose because it was at the top of the list) and it seems to work... but are there any more concrete suggestions anyone might offer?
THANKS
-peter K3IB
Well, Peter, personally i’m skeptical of the benefits of many of the mic profiles. The type of operation, ragchew, Dax, contest, etc. influence the type and amount of audio processing. Also, determining the actual frequency response of a microphone can be more challenging that measuring the frequency response of other equipment, not to mention individual voice characteristics.
Using reports off the air has a lot of variables depending on the settings of the distant station
Since I do mostly DX type operating, I use a flat eq., transmit bandwidth 300-3000 hz, and lots of compression for maximum “punch”, which would probably sound harsh in a ranches qso
If what you are using seems to work, don’t fix it without good reason
You need to adjust your profile according to your voice and it's characteristic. Several tips "how to" using FDX f.ex. if you search this community. For me a couple of You Tube videos by Mike, VA3MW, did the trick. Try f.ex this one: https://www.youtube.com/watch?v=GdFeTzPo14w Flexadio You Tube channel is full of superb videos and "How To" by Mike et all.
Johan, SE3X
I'm using the Arlan Radiosport RS60CF head-set, by tweaking it using FDX, I have made my own profiles. Sounds great I'm told.
I agree with Johan. Another source of great videos is Ken Wells, NM9P. Do a search of his call on YouTube and you will find some excellent videos on the topic.
- 696 The Flea Market
- 121 Aurora
