problems with Quick Playback
i am using 6400m
when I record it comes out distorted
in the software and directly on the radio I did everything in the forum about that problem
who else is going through this
73 "
  • ka9ees
    ka9ees Member ✭✭✭
    @N4RAG
    I had this same problem with an earlier v3 of SSDR. Something was corrupted. I forget what though. What version of software are you running?
  • N4RAG
    N4RAG Member ✭✭
    > @ka9ees said:
    > @N4RAG
    SmartSDR v3.2.39
  • ka9ees
    ka9ees Member ✭✭✭
    @N4RAG
    I would save your profiles. Do a factory reset of the rig.
  • N4RAG
    N4RAG Member ✭✭
    @ka9ees
    ok thanks i will try it,
    I did a test by disconnecting the internet cable from the radio
    reset the radio and it worked fine anyway thanks
    73 "
