Adding Alpha 9500 AMP to Flex 6300
VE3RWY
I have a TS-990S rig and the key out goes to a DX engineering NCC-2 receive antenna phaser's radio PTT key in. On the back of the NCC-2 the optional PTT key out goes to my Alpha 9500 ket it. This works flawlessly.
I would like to share my Alpha amp with my Flex. Can I just a cable from the ALPHA 9500 KEY OUT TO THE flex 6300 key in? Thanks
Yes you can have all the key lines in a loop as long as you are only using one of each at any one time. Thats the way I do it with no problems.
