SSB Settings
Good Evening Flexradio Operators,
I have a new 6400M and so far I have it working just fine with N1MM and also operating CW. I now have my microphone connected with my foot switch. And that seems to be Ok. When I go to the transmit screen I see Timings in MS for RCA TX1, which I have my SPE 1.3K-FA connected to and there are other TX2 and TX3, ACC TX, TX Delay and Time Out. Do I need to make any adjustments to these selections? There is also Interlocks -TX REQ. My RCA is Active Low and the Accessory is the same. The TX EQ is Enabled. Are there certain levels I should have 63 HZ thru 8K HZ set at?
My Microphone level is set at 37. When I press the MIC Speed button, the Proc is at Normal and there are various other settings. Is there any kind of document that would help me to set things the way they should be?
Any help would be very much appreciated.
Mark Griffin, KB3Z
Hi Mark
maybe not what you are asking for, no document. But there are a ton of very helpful You Tube videos on the Flexradio channel. I could think that these might be a good starting point for you https://www.youtube.com/watch?v=GdFeTzPo14w and https://www.youtube.com/watch?v=p79V9Nn8l0U I have had so much help watching the videos. I find it much better watching, than reading :)
Gl/73 de Johan
