LDG AT-100Pro II
KE7FD
[{"insert":"Does anyone know if the flex 6400 "},{"attributes":{"bold":true},"insert":"without an internal tuner"},{"insert":" will work with (an interface cable if any) the LDG AT-100Pro II external tuner? \n"}]
The LDG AT-100ProII is a general purpose automatic tuner, (No Cables necessary). I first tried the LDG AT-100 and if set up as auto tune the 6400 will activate the tuner. I ended up using the MFJ-939Y Auto Tuner. I had much better tuning results with the MFJ. Also, no cables...0
[{"insert":"Thanks. I might get the internal tuner if I don't like the arrangement. I use remote tuners at the base of my two doublets but I still have one antenna that needs a but of help.\nThanks for the comment.\nGlen KE7FD\n"}]1
