Static IP for wired LAN on Maestro B
N6WT Kent
N6WT Kent Member ✭✭
Is there a way to set up a static IP address for the wired LAN port on the Maestro?
Kent
N6WT
  • Al K0VM
    Al K0VM Member ✭✭✭
    Yes,
    Boot up Maestro and radio..
    On Maestro got to Menu>Network>Wifi Settings.. Which will disconnect the radio.
    From the 'Choose Wifi' screen choose 'Advanced'.. From there you should be able to set Static network for Maestro wired..
    But.. It might be better to 'reserve' an address in you router/DHCP server instead of a static address in Maestro.
    AL, K0VM
