MIC-BAL-LINE-ACC
Conny
I feed balanced audio into the Balanced input on my FLEX-6600
Phone/CW setting menu: No BIAS, +20dB
Latest available (downloadable as of today) Smartsdr Software User Guide 3.1.7
• “MIC” selects the 8-pin or 1/8th inch TRS jack input
• “BAL” selects the balanced microphone input
• “LINE” selects the balance microphone input, but disables the +20 dB preamp
• “ACC” selects the rear panel accessory jack
• “PC” selects the Windows Default Recording Device in the host computer
Cycling thru the MIC-BAL-LINE-ACC:
- "MIC" disables the balance microphone input
- "LINE" does not disable the +20dB preamp.
- "ACC" does not disable the balance microphone input.
• Line level inputs (-10 dBV) should be attached to the Accessory connector.
If I select the "LINE" as the input what is the highest line level input?
Any block/flow diagram available for the above scenarios.
- 715 The Flea Market
- 218 SmartSDR+
- 469 SmartSDR for Mac
- 130 Aurora
- 994 Genius Products
- 363 Tuner Genius XL
- 138 Antenna Genius
- 331 Shack Infrastructure
- 235 Networking
