Antenna genius software/firmware
AB8WD
AB8WD Member ✭✭
You list software and firmware for flex/pgxl/tgxl where is support for agxl and software and firmware so we only need to look on one website here. Thanks
  • AB8WD
    AB8WD Member ✭✭
    That's ok but if you use the software from the same page for the pgxl you will find out that it does not match what is on the flex website so you always wonder is up to date or not?
  • David Decoons, wo2x
    Antenna Genius is 3.1.4 currently.
