PTT needed for both the TGXL and PGXL
Hi
I'm expecting my TGXL soon. Currently I am using the PGXL with both a Flex 6700 and ICOM 7610. Question-currently the PTT needed from the ICOM is connected to the PGXL PTT IN. I'm assuming (not in the prelim TGXL manual) that I would connect the PTT OUT on the PGXL to the PTT IN on the TGXL. Or should it be reversed to key the Tuner first and then the PGXL? I realize the Flex has the delays programmed in. What about delays for the PGXL (I adjusted the 7610 as recommended for a slight lag). What about the need for an additional lag now that the TGXL is inline? Your prelim manual shows interfacing only "others: transceivers with the TGXL and not also with the PGXL.
Best Answers
It doesn’t matter whether they’re PGXL or TGXL is first for PTT In. It will work either way.
Mack
Thanks-perhaps something should be mentioned in both the PGXL and TGXL manuals about PTT OUT and it's use.
- 685 The Flea Market
