Removal of previous versions of SmartSDR form the M model and Maestro
Thursday, 3-June-2021:
As noted in the Release Notes and the release announcements for the past two releases, we will be removing several previous versions of SmartSDR from the Maestro and the M Model FLEX-6000s.
It is policy to keep the current released version and one version older on the Version Select screen. Due to several factors, we suspended this policy for several of the previous releases. If you are using an older version of SmartSDR, we strongly encourage you to upgrade to the latest version at your earliest convenience.
We will be removing the following SmartSDR software within the next 24-hours.
SmartSDR 2.4.9
SmartSDR 2.6.1
SmartSDR 3.1.8
SmartSDR 3.2.31
This discussion has been closed.
