WNB setting level from menu
Steve Potter
in Maestro
I have severe wide band noise, very visible on the band, on SmartSDR I can gradually increase the setting until the noise/peaks have gone but on the Maestro the menu isn't translucent enough and I cant see the scope sufficiently so getting the correct setting is a lot of trial and error.
The bottom image doesn't show the extent of the noise as it is fast peaking visually and spans most of 10 meters.
WNB is fantastic and works a treat, just hard to set on the Maestro, could do with a transparency adjustment to the menu background.
- 688 The Flea Market
- 105 Aurora
