IPhone Issues
RFord
RFord Member ✭✭✭
OK I don't know if this is related to the issue Flex is working on....so here goes. Using my IPhone I can connect to my radio via local. If I try to connect via SmartLink it will not connect. I have checked SmartLink Status it looks ok. Last time I tried the SmartLink it was several days ago. It was working fine then. I deleted the app and reinstalled but do luck.
I have upgraded to the latest version v3.2.37 so I'm not sure what to try next.
Thanks in advance for any assistance
Best Regards
Ronald
  • RFord
    RFord Member ✭✭✭
    I did some additional checking...I checked to see if any changes were made to my port forwarding...and I have included a copy of SmartSDR Config screen. When I select the test button it indicates it is testing the connection and then after about 1 minute it shows red. I'm not quite sure what to do next.
    Ronald
  • RFord
    RFord Member ✭✭✭
    I found my issue...turns out to be a port forwarding issue...I have no idea why but it is working now. Administrator please close this thread...
    Ronald
