No FM Modulation When Using Repeater Offset
I am running firmware 3.2.4. I am not sure if it is firmware related, but I have a new observation, post upgrade.
Hoping others, with firmware 3.2.4, could test for the same.
Or, suggestions on what could be causing the problem.
When using the FM mode option for repeater offset, I do not get any FM modulation out. RF out is fine. When using the "Simplex" FM option, I do get FM modulation out.
Same observation on Maestro and on Desktop Smart SDR.
Here is a screenshot of Simplex operation:
And here is a screenshot of Repeater Offset selected:
Alan WA9WUD
Update
Dave, WO2X tested the same configuration on his Flex Radio, with v3.2.34 and all tested OK, so that rules out any firmware design issue.
I did a factory hard reset, and before installing any profiles, tested my configuration again, with the same result, no FM modulation when repeater offset is selected, but all ok when using simplex.
Help Desk ticket submitted.
Alan. WA9WUD
- 688 The Flea Market
- 105 Aurora
- 974 Genius Products
