Power wouldn't adjust above 60 watts.
ka9ees
Member ✭✭✭
I had 80m, 40m and 17m adjusted so the power couldn't be adjusted above 60 watts. I decided I wanted to changed that in the TX Settings. From SSDR for Windows I changed the levels (I typed them in). I was in Smart Control mode at the time.
When I went to the controls on the rig after making this change. The power levels still wouldn't go above 60w...
I ended up having to reset the rig to cure the problem. The profiles loaded in the rig were created in v2.6.2. Not sure if that had anything to do with it or not.
I am running v3.2.34.
- 692 The Flea Market
- 119 Aurora
