Flex 5000a-1394 ports not working
Vladimir Yanchuk
Member ✭
Out of order ports 1394 in the transceiver
Flex 5000a. Replaced the 1394A transceiver chip for 2-channel TI TSB41AB2PAP HTQFP64. The transceiver starts but the computer does not see it. Maybe someone can tell.
Do you have the drivers installed?. Should installed when you first start the software then when you start the 5000 transceiver do you get a notification tone or sound from your computer. You do not need the flex software on just speakers connected to computer and sound volume turned up.
73 Morris WA4MIT
- 685 The Flea Market
