JTDX doesn't transmit when started with Slice Master
I have the latest versions of JTDX, SmartSDR, and Slice Master. I can run stand alone JTDX without any problems. I connect using the Rig " FlexRadio 6xxx" and the Network Server is 5002 corresponding to a SmartSDR TCP port I have set up. Transmit and receive both work.
When I start JTDX through Slice Master, it starts fine. The receive is good. It starts with the rig as Ham Radio Deluxe(as expected) and a local port of 127.0.0.1:7400 or 7852. When I click the Test CAT button, it turns green. The transmit audio is set to DAX Audio TX When I hit the Tune button the rig goes into transmit. There is, however, no power out.
I would really like to be able to start and stop JTDX with Slice Master, but this one I can figure out. If you have any thoughts or suggestions, I would appreciate it. If you need more info, just let me know.
Thanks in advance.
Bob, WK2Y
- 714 The Flea Market
- 210 SmartSDR+
- 467 SmartSDR for Mac
- 129 Aurora
- 993 Genius Products
- 138 Antenna Genius
- 331 Shack Infrastructure
- 235 Networking
