S-Meter without signals covered by TNF
Well, the basic answer is that the TNF works in the audio portion of the radio, and the S meter reading is based on the signal strength at the antenna connection before filtering. This is different than a traditional superhet where the S meter is typically in the IF stage after filtering. But the flex has no IF, being direct sampling of the rf to an ADC for processing by software. Steve Hicks from flex has a recent YouTube video on this. I had the same question, but got the above answer at the flex booth at a ham fest.
The S-Meter only takes into account what is in the passband. Signals 10 Hz outside the filter have no influence at all (gotta love DSP!!). It is a matter of programming to remove the TNF slice(s) from the data that comprises the filter passband. Not a trivial task I would imagine, but certainly possible. It may not be worth doing if it would increase latency appreciably (maybe a Flex engineer could comment on this).
The S-Meter does not "see" the antenna connection, it is software that processes the data once the RF signal has been digitized in the ADC. It is coded such that it only uses the data within the filter passband. If this were not so, then the largest signal on the panadapter would generate the S-Meter reading.
- 409 Community Topics
- 707 The Flea Market
- 207 SmartSDR+
- 464 SmartSDR for Mac
- 223 DAX
- 125 Aurora
- 367 FLEX-8000 Signature Series
- 984 Genius Products
- 360 Tuner Genius XL
- 328 Shack Infrastructure
- 233 Networking
