Using Teamviewer to connect my remote Ipad to the shack PC drops
I have been using Teamviewer to connect my remote Ipad to the shack PC to control and access shack functions ie. rotor, watt meter, amp control etc while using my remote Flex.
If I am running WSJT-X and smart SDR on my shack PC, the connection is good and everything works fine. If I want to operate SSB or CW when I am remote, I use the smart SDR IOS app from Marcus which also works great. The problem is that when I change what is being displayed on my Ipad to the SDR IOS app, the teamviewer connection to the home PC disconnects and I will not me able to monitor any of the shack accessories. I can re connect while running the SDR IOS app and make any changes like rotate the antenna, but the Teamviewer connection will be lost again after about 5 seconds after I switch back to the SDR screen.
Is there a way to keep Teamviewer connected to the remote PC when the display on the Ipad moves away from the Teamviewer screen?
Thanks, Howard AE3T
The iPad, like most tablets/phones is not a multi-tasking OS like windows, Linux, macOS. It can only do one thing at a time. For example, it can’t check email while also downloading a large document.
howard. I know this thread is older, but i use Splashtop and it will allow you to keep the screen open and jump back and forth between it and SmartSDR iOS app.
- 683 The Flea Market
