SmartSDR v3.2.31- Bandwidth not saved with profile?
Has anyone had a problem with SmartSDR v3.2.31 not saved the Bandwidth when a new profile is saved?
No matter how many times I try to save a profile with my SSB Bandwidth set for 2.4 it does not stick. When the profile is loaded the Bandwidth is always set to 2.7.
I never found this to be a problem in the past with older versions of SmartSDR.
    Hi Ken, they are working properly for me (Flex 6400, V3.2.31). I would suggest exporting your profiles, do a factory reset on the Flex, then re-import the profiles to see if that fixes the problem. If not, it is probably time to submit a helpdesk ticket.
  • Ed Stallman
    Ed Stallman Member ✭✭
    Ken did you find a fix ? My bandwidth will not save . I've tried saving the profile many time but it defaults to 400Hz.
    Ed N5DG
