Powerwerx ss 300v power supply
will the Powerwerx ss 300v power supply run the 6400 at full power?
Best Answers
    Answer ✓
    Hi Don, this is a 25 A continuous, 30 A peak supply. The 6400 takes 23 A max on transmit, so this supply should work.
  • Erika - KØDD
    Erika - KØDD Member ✭✭✭
    Answer ✓
    If you don't own it already go bigger.
  • Erika - KØDD
    edited March 2021 Answer ✓
  • HoosierFlexDaddy
    HoosierFlexDaddy Member
    Answer ✓
    [{"insert":"Flex sells them at their store, so Flex thinks they’re good !\n"}]
  • HoosierFlexDaddy
    Answer ✓
  • Steve KD2OM
    Steve KD2OM Member ✭✭
    Answer ✓
    Switching supplies have no business near an HF radio in my opinion. Linear is the only way to go.
    Steve KD2OM
