Mic adapter
iz7auh
Member ✭✭✭
Hi,
I am Frank, IZ7AUH I need make an adapter for my Yaesu MD-100 microphone on my Flex-6400, I see on reference manual a pin out connection, but I don't want mistake, I read TIP for MIC+ and RIng for Negative, I am not sure if I need conect a RING o **** for ground mic yaesu mic gnd, can you explain me about?
Best regards.
Frank IZ7AUH
Hi Frank,
Connect Yaesu's pin 8 to TIP, pin 7 to RING, and pin 5 to SLEEVE.
Then connect pin 6 to the RCA PTT jack.
MD 100 is a dynamic mic so you will have to disable the Bias in the Flexradio menu.
73, Demetri0 -
Hi Demeti, tnx for your support, work great a MD-200 on FRS 6400....
