Ameritron ALS-606 band switching
I'm using the 6400 with SmartSDR 3.1.12, attached via a commercially made interface to an Ameritron ALS-606 amplifier. It has worked flawlessly for months, but suddenly the auto-band switching is no longer functioning. The amp works fine if I dial in the proper band manually. The manual says this problem comes down to one of three things -- is the radio sending the proper codes, is the interface working properly, or is there a problem in the logic circuit of the autoswitcher. Stop number one -- how to determine if the radio is sending the proper codes. Is there a way to register those codes in a logger and then compare them to what is correct? I'll appreciate any suggestions.
JP, K5JPP
JP, K5JPP
- 407 Community Topics
- 705 The Flea Market
- 204 SmartSDR+
- 464 SmartSDR for Mac
- 223 DAX
- 124 Aurora
- 983 Genius Products
- 328 Shack Infrastructure
- 233 Networking
