RTTY issues with V2.6.2
Pat Hoppe
Member ✭
Hello,
I am running V2.6.2 of the SDR software. When I use the SDR software in RTTY mode, It works fine until I change bands. If I change the band, it will no longer transmit. If I shut down and restart the SDR software, it transmits again.
I am using the latest version of N1MM+ and 2Tone to decode.
Has anyone run into this problem and if so, how did you fix it? Having to reboot the SDR software for every band change is a real issue.
Pat WW9R
Pat WW9R
I do not have the N1mm but I ran into a similar one like your. After many trials I discover to set the RTTY program as Administrator, right click and go to properties . Change the Compatibility to Administrator, while I was typing I remember that you can also try to set it to windows 7 or 8 under the same properties menu, try this before you setting it to administrator.
- 713 The Flea Market
- 210 SmartSDR+
- 466 SmartSDR for Mac
- 128 Aurora
- 991 Genius Products
- 330 Shack Infrastructure
- 234 Networking
